Assign expense categories from the Activities window
  1. Choose Project, Activities.
  2. Select the activity associated with the expense.
  3. Display Activity Details, then click the Expenses tab. To display the Expenses tab, click the Layout Options bar and choose Bottom Layout Options. In the Available Tabs section, select Expenses, click
     , then click OK.
  4. Select the expense to which you want to assign a category. Double-click in the Expense Category column, then click "".
  5. Select the category you want to assign, then click the Select button.
