Assign funding sources
Once you define funding sources, you can assign them to EPS nodes or projects as follows:
- Choose Enterprise, Projects, then select the EPS node/project to which you want to assign a funding source.
- Display Project Details, then click the Funding tab.
- Click Add.
- Select a funding source from the Funding Sources Dictionary.
- Click
, then click
- Type the amount of funding to be allocated to this project.
- Type a percentage or share of the total fund to be allocated to the selected element. You can assign the same funding source multiple times with varying amount and share contributions for different levels of the EPS. Both the amount and share values for the fund are user-defined. Funds do not roll up; you edit them per EPS level to allow for top-down planning.
Tip:
In the Projects window you can include a column called Total Funding, which contains the sum of the funding for each project and EPS node.
