Assigning a project manager delegate for timesheets
  1. Choose Tools, Approve, Timesheets.
  2. Select Delegate > Project Manager Delegate.
  3. For each project for which you want delegate timesheet approval, in the Delegate column click "", select a user, and click "".
  4. Mark the checkbox next to each of the projects for which you want to delegate timesheet approval.
  5. Click Apply.
Tip:
You can set up approval delegates for projects separately from activating the delegated responsibility. For example, if you will always delegate timesheet approval responsibilities for a project to the same person when you are out of the office, you can select that user and click Apply to assign them as a delegate. At a later date, you can mark the checkbox next to the projects for which you want to delegate approval responsibilities and click Apply to activate the delegation responsibilities to the associated users.
