Assign WBS Category values (P6 Professional Only)
You can assign a WBS category value from the Work Breakdown Structure window.
  1. Display a column for the WBS category, if it is not already displayed. Click the Display Options bar, choose Columns, and then choose Customize. In the Available Options section, under the General subsection, choose the WBS category. Click
     , then click OK.
  2. In the WBS table, select the WBS element to which you want to assign a WBS category value, then double-click in the WBS category column.
  3. Double-click the category value you want to assign.
