Change an activity's work breakdown structure assignment
  1. Choose Project, Activities.
  2. Select the activity whose WBS assignment you want to define or change.
  3. Display Activity Details, then click the General tab.
  4. In the WBS field, click "" , then select the WBS element to which you want to assign the selected activity.
  5. Click the Select button.
