Change a profile's background lines
- Right-click on the profile and choose Activity Usage Profile Options, Resource Usage Profile Options, or Profile Settings, depending on the type of profile and the active window.
- Click the Graph tab.
- To display a vertical background line for major and/or minor timescale increments, in the Vertical Lines area, mark the corresponding checkbox. For example, in a Year/Month format timescale, major lines would display between years; minor lines would display between months.
- To display horizontal lines for each numerical increment listed along the side of the profile, choose the type of line you want to display, then select the line color. Choose None to hide background horizontal lines.
- To specify additional profile display options, mark the corresponding checkbox(es): Show Legend: Mark to display a legend for the profile's bars. 3D Bars: Mark to display the profile's bars in 3D. Background Color: Click to change the profile's background color.
