Change a project's status
  1. Choose Enterprise, Projects and display Project Details.
  2. Select the project whose status you want to change, then select the project status you want to use for the current project. This selection affects data access as follows:
Status Impact
Planned Sets all project WBSs to Planned.
Active Sets all project WBSs to Active.
Inactive Sets all project WBSs to Inactive.
What-If
Sets all project WBSs to What-If.
Project is included when summarizing.
Project is ignored by resource profile/spreadsheet and leveling.
The Status field applies to projects only, not EPS nodes.
