Change expenses tab columns
  1. Click the Expenses tab.
  2. Right-click anywhere in the Expenses tab, then choose Customize Expense Columns. To add a specific column to the Expenses tab, select it in the Available Options area, then click
    .To remove a specific column from the Expenses tab, select it in the Selected Options list, then click
    . To apply your changes without closing this dialog box, click Apply.
  3. Click OK.
Tip:
  • To move all available columns to either Available Options or Selected Options, click "" or "".
  • To reset the Expenses tab so that it contains only the default columns, click Default.
  • Double-click an item in the Available Options or Selected Options area to move it to the opposite column.
  • To edit a column's title, width, and alignment, click Edit Column.
