Change global profiles (P6 Professional Only)
- Choose Admin, Security Profiles.
- Choose Global Profiles. To change a profile's name, double-click the profile, then type a new name. To make a profile the default profile, mark its corresponding Default checkbox. To change a profile's privileges, select the profile, then mark or clear the checkboxes to grant or deny each privilege.
