Change Resource Security (P6 Professional Only)
You can change each user's resource access in the Users dialog any time. The new settings apply when the user logs in.
To change resource security:
- Choose Admin, Users.
- Click the Global Access tab.
- Select a user from the list. The bottom of the Global Access tab displays the selected user's current resource access information.
- Change the user's resource access settings.
- While a user is working offline, changes to certain data can cause them not to be able to switch to working online. To ensure users who are currently working offline are not prevented from switching to working online, avoid making changing any of the following data if any user might currently be working offline: User details, Global or project security profiles, OBS assignments (both for users and for projects), and Resource security.
- Since a user's resource access depends on the position of the assigned resources in the hierarchy, changing that position also means changing the user's resource access.
