Change the expense categories display
When P6 Professional is connected to a P6 EPPM database, you can use P6 to control the order in which your expense categories are listed in the Select Expense Category dialog box.
When P6 Professional is connected to a P6 Professional database, you can control the order in which your expense categories are listed in the Select Expense Category dialog box.
This dialog box is displayed when you assign expense categories in the General tab of the Project Expenses window or the Activity Details Expenses tab.
