Change the global code separator (P6 Professional Only)
The global code separator is the character that separates cost account and activity codes to indicate hierarchy levels. The global code separator is used to indicate work breakdown structure (WBS) hierarchy levels if you do not specify a code separator for a project.
- Choose Admin, Admin Preferences.
- Click the General tab, then type a new code separator character in the Code Separator section.
