Change the resource's role assignments for an activity
  1. Choose Project, Activities.
  2. Select the activity for which you want to change a resource's role.
  3. Display Activity Details, then click the Resources tab.
  4. For the appropriate resource listing, double-click in the Role column.
  5. Select the role you want to assign, then click the Select button.
Tip:
If the Role column is not displayed in the Resources tab, right-click anywhere in the tab, then choose Customize Resource Columns. In the Available Options area, click Role, click the right arrow button, then click OK.
