Checking schedules
The Check Schedule Report analyzes the schedules of open projects allowing you assess project heath metrics. You can specify your own target percentages for each report parameter.
The Check Schedule Report looks for warning signs of potential issues:
Inflexibility and Inefficiency
Inflexibility and inefficiency in a schedule can cause unnecessary project overruns.
Inflexibility occurs when too many activities are constrained or activities are not linked by schedule logic to reasonable predecessors or successors.
A schedule might be inefficient if some activities have very long durations, lags, or float. For example, if an activity has a very long duration its successors might be unnecessarily prevented from starting work, whereas breaking the activity down into several shorter activities might provide for more parallel working. When a relationship has a long lag or a large amount of float, it might be that the schedule would be more efficient if the activities were joined with different activities.
The following checks can help you to identify inflexibility and inefficiency in a schedule:
- Logic - Activities missing predecessors or successors
- Negative Lags - Relationships with a lag duration of less than 0
- Positive Lags - Relationships with a positive lag duration
- Long Lags - Relationships with a lag duration greater than 352 hours
- Relationship Types - The majority of relationships should be Finish to Start
- Hard Constraints - Constraints that prevent activities being moved
- Soft Constraints - Constraints that do not prevent activities being moved
- Large Float - Activities with total float greater than x
- Negative Float - Activities with a total float less than 0
- Large Durations - Activities that have a remaining duration greater than x
- Invalid Progress Before Data Date - Incomplete activities before the data date
- Invalid Progress After Data Date - Activities with actual dates after the data date
- Resources/Cost - Activities that do not have an expense or a resource assigned
- Late Activities - Activities scheduled to finish later than the project baseline
- Baseline - Activities missing assigned baseline
- Links to Closed Projects - Activities with links to closed projects
- Out of Sequence - Activities which are completed or in-progress before their predecessors
- Dangling Start Activities - Activities with start dates that are not driven by predecessors
- Dangling Finish Activities - Activities with finish dates that do not drive successors
Inaccuracy
Accuracy in a schedule relies on progress being reported accurately and costs being assigned appropriately.
The following checks can help you identify potential inaccuracy in a schedule:
- Invalid Progress Dates - Activities with invalid progress dates
- Resource / Cost - Activities that do not have an expense or a resource assigned
Lateness
If work is running late, it might be possible to take corrective action by adjusting the schedule. Alternatively it might be necessary to manage expectations of stakeholders.
The following checks can help you identify lateness in the schedule:
- BEI - Baseline Execution Index
