Collapse all information in a tracking layout
When information in the Top Layout window is displayed in a table or spreadsheet, you can quickly close all detailed levels of information to display only the highest level.
  • Choose View, Collapse All or click the Display Options bar in the Layout window and choose Collapse All. You can also right-click in the Top Layout window, then choose Collapse All.
