Combine text fields
You can use Global Change to modify text data items such as activity IDs and names, and activity codes by linking two text fields using the ampersand (&) operator. This is called concatenation. The following statement adds the Location activity code value to the Activity ID field, if a value is assigned to the activity:
Then: Activity ID = Activity ID & Location
Tip:
Use a dash (-) or underscore (_) to represent spaces when concatenating data.
