Convert a shared resource calendar to a personal resource calendar
- Choose Enterprise, Calendars.
- Choose Resource.
- Select the shared resource calendar you want to convert to a personal resource calendar.
- Click To Personal.
- Proceed as follows:
- If a single resource is assigned to the calendar, a confirmation message appears. Click Yes.
- If no resources are assigned to the calendar, the Select Resource dialog box appears. Select a resource to assign to the calendar. A confirmation message appears. Click Yes.
- You cannot convert a shared resource calendar to a personal resource calendar when multiple resources are assigned to calendar.
- The calendar is not renamed when it is converted from a shared resource calendar to a personal resource calendar.
