Cost accounts
You can create cost accounts and associate them with activity resource assignments or expenses in a project.
Cost accounts are hierarchical, and they enable you to track activity costs and earned value according to your organization's specific cost account codes.
You can specify a project's default cost account. This cost account is used for resource assignments to activities and project expenses in the open project.
If you receive the message, "Too Many Cost Account Items To Display," when opening the Cost Account Library, switch to Table View. If you must use the Chart View, apply a filter to show less data.
