Create a baseline type
When P6 Professional is connected to a P6 EPPM database, you can use P6 to create baseline types that you can assign to baselines in any project. You can use baseline types to standardize baselines for all projects.
When P6 Professional is connected to a P6 Professional database, you can create baseline types that you can assign to baselines in any project. You can use baseline types to standardize baselines for all projects.
  1. Choose Admin, Admin Categories.
  2. Click the Baseline Types tab, then click Add.
  3. Type the name of the new baseline type.
