Create a global calendar
  1. Choose Enterprise, Calendars.
  2. Choose Global, then click Add.
  3. Select the calendar you want to copy for the new global calendar, then click the Select button.
  4. Type the new calendar's name.
  5. Mark the Default checkbox to make the new calendar the default global calendar for activities and resources.
  6. Click Modify and edit the new calendar.
