Create a personal resource calendar
Use this task to create and assign a personal resource calendar.
When P6 Professional is connected to a P6 EPPM database:
- You must have the Add/Edit/Delete Resource Calendars privilege, as defined in P6, to create personal resource calendars.
- Before you create a personal resource calendar for a user, the user must be defined (using P6), a resource representing the user must be defined (using P6 or P6 Professional), and the user must be associated with the corresponding resource (using P6).
- You must have the Add/Edit/Delete Resource Calendars privilege to create personal resource calendars.
- Before you create a personal resource calendar for a user, the user must be defined, a resource representing the user must be defined, and the user must be associated with the corresponding resource.
When P6 Professional is connected to a P6 Professional database:
- Choose Enterprise, Calendars.
- Choose Resource.
- Select any row in the Personal Resource Calendars group, or click the Display Options bar, then click Filter By, Personal Resource Calendars and select any row.
- Click Add.
- In the Select Resources dialog box, select the resource for which you want to create a personal resource calendar.
The list of resources does not include resources already assigned to a personal resource calendar unless you filter the list of resources by All Resources.
- Click the Select icon.
- In the Calendars dialog box, click Modify and edit the new calendar.
