Create EPS-level activity code values
  1. Choose Enterprise, Activity Codes.
  2. Choose EPS.
  3. Select the activity code for which you want to create a value, then click Add.
  4. Type the value's name.
  5. Type the value's description.
Tip:
  • You can arrange activity code values hierarchically using the arrow buttons on the Activity Codes dialog box.
  • You can define the maximum number of levels in an activity code hierarchy on the Data Limits tab of the Admin Preferences dialog box when P6 Professional is connected to a P6 Professional database and from the P6, Application Settings when connected to a P6 EPPM database.
  • You can also create a new activity code value when assigning an activity code value to an activity.
