Create role codes
- Choose Enterprise, Role Codes.
- Click Modify.
- Click Add, then type the name of the role code.
- In the Max Length field, specify the maximum number of characters for the role code's values.
- Click Close.
If you intend to use reporting software, avoid using commas when creating data other than Project names. The way that data is passed to some reporting software can cause a comma to be interpreted as a delimiter between data items.
Tip:
To change the order in which role codes are listed, select the role code you want to move in the Role Code Definitions dialog box, then click Shift Up or Shift Down.
