Customize a Project Bar Chart
You can customize an existing Project Bar Chart by specifying the data you want each bar to represent, selecting the bar display options, and specifying how the information is grouped and sorted.
  • Display the Project Bar Chart, then use the View menu to select the type of information you want to change.
