Cut and paste activities in the Activity Network
- Select the activities you want to cut and paste.
- Choose Edit, Cut.
- Select the group band (or another activity box within the group band) where you want to insert the cut activities, then choose Edit, Paste.
- When connected to a P6 EPPM database: When you cut and paste activities within the same project, any associated risks from P6 are also moved; risks are not moved when you cut and paste activities to a different project.
- When connected to a P6 Professional database: When you cut and paste activities within the same project, any associated risks are also moved; risks are not moved when you cut and paste activities to a different project.
