Default filter criteria
The following table lists the criteria used for the predefined activity filters.
| Filter Name | Display all rows | Parameter | Is | Value |
| Completed | Where | Activity Status | Equals | Completed |
| Critical | Where | Critical | Equals | Yes |
| Has Finish Constraint |
Where Or Or Or Or Or Or Or |
Primary Constraint Primary Constraint Primary Constraint Primary Constraint Secondary Constraint Secondary Constraint Secondary Constraint Secondary Constraint |
Equals Equals Equals Equals Equals Equals Equals Equals |
Finish On Finish On or Before Finish On or After Mandatory Finish Finish On Finish On or Before Finish On or After Mandatory Finish |
| Has Start Constraint |
Start On Start On or Before Start On or After Mandatory Start Start On Start On or Before Start On or After Mandatory Start |
| In Progress | Where | Activity Status | Equals | In Progress |
| Level of Effort | Where | Activity Type | Equals | Level of Effort |
| Longest Path | Where | Longest Path | Equals | Yes |
| Milestone |
Where Or |
Activity Type Activity Type |
Equals Equals |
Start Milestone Finish Milestone |
| Negative Float | Where | Total Float | Is less than | 0.0d |
This criterion only appears when P6 Professional is connected to a P6 Professional database. New Feedback to Review |
Where | New Feedback | Equals | Yes |
| Non What-If | Where | Project Status | Is not equal to | What If |
| Non Critical | Where | Critical | Is not equal to | Yes |
| Normal |
Where Or |
Equals Equals |
Task Dependent Resource Dependent |
| Not Started | Where | Activity Status | Equals | Not Started |
