Define a what-if project
P6 Professional enables you to create projects for examining "what-if" scenarios, known as what-if projects. You might choose to copy a project before changing its status to "What-If" so that this change does not impact other projects in the EPS.
  1. Open the project whose status you want to change to “what-if.”
  2. Choose Enterprise, Projects and display Project Details.
  3. Click the General tab.
  4. Select What-If in the Status field.
    Changing a project's status requires the appropriate access rights.
