Define maximum hierarchy levels (P6 Professional Only)
  1. Choose Admin, Admin Preferences.
  2. Click the Data Limits tab.
  3. Specify the number of hierarchy levels each hierarchy may have.
    If you change maximum hierarchy level settings, your change only applies when you add new elements or edit existing elements.
