Delete a baseline
  1. Choose Project, Maintain Baselines. Select the baseline you want to delete, click Delete, then click Yes.
    You cannot delete an active baseline. An active baseline is any baseline marked as the primary, secondary, or tertiary baseline in the Assign Baselines dialog box.
