Delete a financial period (P6 Professional Only)
- Choose Admin, Financial Period Calendars.
- Click the financial period calendar containing the period you want to delete.
- In the list of financial periods, select the period you want to delete.
- Click Delete.
- You cannot delete a financial period that contains past period actual data for at least one project. If you attempt to delete multiple financial periods at the same time, none of the financial periods will be deleted if any period contains past period actual data. In this case, to delete a financial period, you must archive and delete the project containing past period actuals, then delete the financial period.
- You must have the Add/Edit/Delete Financial Period Calendars global privilege to delete a financial period.
