Delete a global calendar
- Choose Enterprise, Calendars.
- Choose Global.
- Select the calendar you want to delete, then click Delete.
- If the calendar has assignments, the Calendars in Use dialog box is displayed. To delete the calendar and move its assignments to a calendar you select, choose Select Replacement Calendar, click OK, then select a replacement calendar. To delete the calendar and move its assignments to the default global calendar, choose Link to Default Global Calendar, then click OK.
