Delete an EPS node or project
  1. Choose Enterprise, Projects, then select the EPS node or project that you want to delete. Choose Edit, Delete.
  2. Click Yes to confirm.
Tip:
When you delete an EPS node, all projects in that branch of the hierarchy are also removed. To save projects in a branch before deleting it, first copy and paste those projects to another area of the hierarchy.
