Delete a portfolio
- Choose Enterprise, Project Portfolios.
- Select the portfolio you want to delete.
- Click Delete.
- Click Yes.
Tip:
- If a user is working within a portfolio you delete, the user will not see an immediate impact. When the user chooses Refresh, a message will indicate that the portfolio has been deleted. If a new portfolio is not selected, all projects are loaded.
- You cannot delete a filtered portfolio in P6 Professional.
