Delete a project calendar
  1. Choose Enterprise, Calendars.
  2. Choose Project.
  3. Select the calendar you want to delete, then click Delete.
  4. If the calendar has assignments, the Calendars in Use dialog box is displayed. To delete the calendar and move its assignments to a calendar you select, choose Select Replacement Calendar, click OK, then select a replacement calendar. To delete the calendar and move its assignments to the default global calendar, choose Link to Default Global Calendar, then click OK.
