Delete a resource curve
- Choose Enterprise, Resource Curves.
- Select the global curve you want to delete. You cannot delete the default curves.
- Click Delete.
- Click Yes.
If you delete a resource curve assigned to a resource or role assignment, the curve is removed from the assignment and the actual values and earned value for those assignments are recalculated.
