Delete EPS level activity codes
- Choose Enterprise, Activity Codes.
- Choose EPS, then click Modify.
- Select the code you want to delete, then click Delete.
- Click Yes.
When you delete an EPS-level activity code, all code values associated with the deleted activity code and all activity assignments to those activity code values are automatically deleted.
