Delete icons from toolbars
You can delete an icon from any currently displayed toolbar. To delete an icon:
- Choose View, Toolbars, Customize. Opening the Customize dialog box switches the toolbars into Edit mode, which enables you to delete icons. You do not need to use the Customize dialog to delete icons; however, you must leave the dialog open to enable you to delete icons.
- Right-click on the icon you want to delete, then choose Delete. Repeat for each icon you want to delete.
- Click Close in the Customize dialog box. When you close the Customize dialog box, the toolbars revert to their previous state, minus any previously displayed icons that you deleted.
Tip:
When you delete an icon, it is no longer available for display. To recover deleted icons, you must revert to the default settings for an individual toolbar, or for all toolbars.
