Delete project activity codes
  1. Choose Enterprise, Activity Codes.
  2. Choose Project, then click Modify.
  3. Select the code you want to delete, then click Delete.
  4. Click Yes.
    When you delete a project activity code, all code values associated with the deleted activity code and all activity assignments to those activity code values are automatically deleted.
