Delete Units of Measure (P6 Professional Only)
You can delete any available unit of measure.
- Choose Admin, Admin Categories.
- Select the Units of Measure tab, then select a Unit Abbreviation or Unit Name.
- Click Delete.
If the units of measure you attempt to delete is in use, a message will prompt you that the unit of measure is still in use. Click Yes to continue deleting. The unit of measure is deleted from the resource, but the resource remains.
