Disable Resource Security (P6 Professional Only)
Resource security allows the administrator to restrict a user's resource information access by assigning the user to up to five resource nodes in the hierarchy. Those resource nodes are the user's root nodes. Once assigned to those root nodes, the user has access only to those resource node and all of their children.
To disable resource security:
  1. Choose Admin, Users.
  2. Click the Global Access tab.
  3. Select the user from the list. The bottom of the Global Access tab displays the selected user's current resource access information.
  4. Select All Resources.
    • All Resources This option disables resource security for the selected user and gives access to all resources.
      Admin Superuser always has All Resources access, regardless of the resource security access settings.
