Display resource data as a profile or spreadsheet
  1. In the Tracking window, open or create a Resource Analysis layout, then, in the Resource Explorer window, select the resource(s) whose allocation you want to view.
  2. To display a profile of the selected resource's allocation for one or more projects selected in the Project Explorer window, in the Top Layout window, click
    . To display a spreadsheet of the selected resource's allocation for one or more projects selected in the Project Explorer window, in the Top Layout window, click
  3. To display a profile of the selected resource's total allocation (all projects across the enterprise), in the Bottom Layout window, click "".
  4. To display a spreadsheet of the selected resource's total allocation (all projects across the enterprise), in the Bottom Layout window, click "".
    If the projects you select are not currently open, it is necessary to run the summary job service to see the resource data. To view resource data live, open the projects.
