Duration % of Original (%)
A Duration % of Original threshold value is expressed as a percentage. An issue is generated if the ratio of the activity's actual duration to its original duration (actual duration / original duration * 100) falls beyond the threshold values.
The ratio of actual duration to original duration may be greater than 100.
