Edit a baseline type (P6 Professional Only)
- Choose Admin, Admin Categories.
- Click the Baseline Types tab.
- Double-click the baseline type you want to change, then enter a new baseline type.
Tip:
- To change the order in which baseline types are listed, select the baseline type you want to move, then click Shift Up or Shift Down.
- If you change a baseline type, your change applies to all baseline assigned that baseline type.
