Edit a statement
- Choose Tools, Global Change.
- Select a global change specification, then click Modify.
- Click in the If, Then, or Else sections of the Global Change dialog box.
- Double-click the parameter, criteria, parameter/value, or operator you want to change.
- Type or select a new data item, condition, operator, or value.
- Changing some parameters of an If, Then, or Else statement may affect the operators and criteria available in the statement.
- Changing the subject area of a specification will clear all existing If, Then, and Else statements.
