Edit project-level activity code values
  1. Choose Enterprise, Activity Codes.
  2. Choose Project.
  3. Select the code whose value you want to change.
  4. To change a value or description, double-click the item you want to change, then type the new text. To change the placement of the code in the list, click the appropriate arrow.
  5. Click Close.
Tip:
If you change an activity code value, your changes apply to all activity assignments.
