Edit project codes
  1. Choose Enterprise, Project Codes.
  2. Click Modify.
  3. Select the project code you want to edit. To change the project code's name, type a new name. To change the maximum number of characters the code's values may have, specify a new number. To change the placement of the code in the list, click Shift Up or Shift Down.
  4. Click Close.
Tip:
If you change a project code, your changes apply to all project assignments.
