Edit the WBS category (P6 Professional Only)
You can use a custom work breakdown structure (WBS) category to organize and maintain WBS information in all projects.
- Choose Admin, Admin Categories.
- Click the WBS Category tab, which displays the current name of the WBS category, for example Project Phase. Project phase is the default WBS category. (See the graphic below.)
- In the WBS Category field, type the new WBS category name. (This name will appear in the associated tab on the left side of this dialog box.)
The category's current values and value assignments do not change when you change the WBS category.
