Establish budgets
  1. Choose Enterprise, Projects, then select the EPS node/project for which you want to enter budgets.
  2. Display Project Details, then click the Budget Log tab.
  3. In the Original Budget field, type an estimate of the total amount you require for this project, including all funding contributions.
