Exchanging data with Primavera Unifier using Activity Sheet Integration
Caution:
Caution Check with your administrator what type of integration you are using and which actions you should use. Choosing the incorrect integration type or using the incorrect action could result in data corruption.
To exchange data with Primavera Unifier using activity sheet integration:
  1. Open the project or projects that you want to exchange with Primavera Unifier.
  2. Select Exchange Data, from the File menu and then select an action.
  3. If the action you selected is an export action, in the action dialog box:
    1. Mark Activity Data.
    2. Verify that the projects you want to send to Primavera Unifier are listed.
    3. Click Send.
      • You must have the Exchange Project Data with Primavera Unifier privilege set in P6 and P6 EPPM must be configured for integration with Primavera Unifier.
      • Before you exchange project data with Primavera Unifier you must link a project with a Primavera Unifier project.
      • The first time you exchange data between P6 Professional and Primavera Unifier using activity sheet integration, you must initiate the exchange from Primavera Unifier. After the first time, you can initiate the exchange of data either from Primavera Unifier or P6 Professional.
