Exchanging data with Primavera Unifier using Schedule Sheet Integration
Caution:
Caution Check with your administrator what type of integration you are using and which actions you should use. Choosing the incorrect integration type or using the incorrect action could result in data corruption.
To exchange data with Primavera Unifier using schedule sheet integration:
- Open the project or projects that you want to exchange with Primavera Unifier.
- Select Exchange Data, from the File menu and then select Send to Schedule Sheet.
- You must have the Exchange Project Data with Primavera Unifier privilege set in P6 and P6 EPPM must be configured for integration with Primavera Unifier.
- Before you exchange project data with Primavera Unifier you must link a project with a Primavera Unifier Project.
